ACL Slices and Rules
The ExtremeSwitching series switches use a mechanism different from the earlier ExtremeSwitching series to implement ACLs. The same
			architecture and guidelines apply to both
					platforms.
Instead of the per port masks used in earlier switches, these
platforms use slices that can apply to any of the supported ports.
An ACL applied to a port may be supported by any of the slices.
The slice support is as follows:
				- 4120 switches—
						- Eight ingress stage slices with 2,000 single-wide rules
						- Four VLAN look-up stage slices with 512 rules
						- Four egress stage slices with 512 rules
				- 4220 switches—
							single-wide rules
				- ExtremeSwitching 5320 switches—
							slices with 1,024 rules for 5320-48TP models.
						- Eighteen ingress stage slices with 16,000
							single-wide rules for 5320-48T/P and 24 and 16-port models.
						- Eighteen ingress stage slices with 8,000
							double-wide rules for 5320-48T/P and 24 and 16-port models.
							with 1,024 rules for 5320-48T/P models.
							rules for 5320-24 and 16-port variants models.
						- Four egress stage slices with 512 rules for
							5320-24 and 16-port variants.
				- ExtremeSwitching 5420 switches—
							slices with 1,024 rules.
							slices with 36,000 single-wide rules for 5420M models.
							slices with 16,000 single-wide rules for 5420F models.
							slices with 18,000 double-wide rules for 5420M models.
							slices with 8,000 double-wide rules for 5420F models.
							with 1,024 rules.
				- ExtremeSwitching 5520 switches—
							slices with 2,048 rules.
							slices with 18,000 single-wide rules.
							with 1,024 rules.
				- ExtremeSwitching 5720 switches—
							slices with 36,000 single-wide rules for 5720-MXW models.
						- Twelve ingress stage
							slices with 18,000 single-wide rules for 5720-MW models.
							slices with 18,000 double-wide rules for 5720-MXW models.
							slices with 9,000 double-wide rules for 5720-MW models.
							with 2,048 rules.
				- Extreme 7520 switches—
						- Four VLAN look-up stage slices with 1,024 rules.
						- Eighteen ingress stage slices with 36,000 single-wide rules.
						- Twelve ingress stage slices with 18,000 single-wide rules.
						- Eighteen ingress stage slices with 18,000 double-wide rules.
						- Twelve ingress stage slices with 9,000 double-wide rules.
						- Four egress stage slices with 2,048 rules.
				- Extreme 7720 switches—
